Winter gas causing rough idle?
Car: 1991 RS
Engine: L69?
I've noticed since the switch to winter gas i have a pretty rough idle, to the point where the whole car shakes a bit when stopped in gear. It isn't just the weather, there were a few warm days where the same symptoms existed, but the second I give it gas to go it runs smooth. Now I have my timing advanced to about 8* and have had no problems during the summer. Would bumping it down to 2 or 4 or even stock 0 smooth the idle out? I've already replaced a ton of sensors and fixed vacuum leaks due to a previous problem that has been taken care of. Anything else I should look at?
Edit: I also would like to stress that I have an l69 that uses the EFI system from my stock L03 so I'm not necessarily operating under normal conditions. This has been a problem diagnosing things before.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Winter gas causing rough idle?
If it's shaking at idle, then smoothing out, check yoru plugs and plug wires, could be a cylinder misfiring. When was the last time you did a full tune up with plugs, wires, cap and rotor?
When my #8 plug wire melted to my headers due to poor routing I lost that cylinder. It would run smooth on the highway but as soon as I got down to idle it would get rough and shake a little.
Car: 1991 RS
Engine: L69?
Car: 1984 Trans Am
It would be worth a check anyway. It's still running so the issue isn't that bad.
