help
Car: 1987camaro irocz28
Engine: 5.7
Axle/Gears: 373
help
need some help i just got building my 87 camaro i put aluminum heads, a thumper comp cam, long tube headers and 32lb injectors. the car starts and runs but will not idle on its own in order for it to keep running i have to keep my foot on the pedal. its also running lean.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help
Why such big injectors in a 350, guys run 24's in 383's?
I suspect if you have a stock tune it will be super rich with injectors that big
Engine: 5.7
Axle/Gears: 373
Re: help
no i have not done a tune yet.
if i put a custom chip in it will it help? where is the best place to get a custom chip made...cheap?
if i put a high pressure fuel pump in it will that help the running lean issue?
Car: 82 Z28
Transmission: T400
Re: help
Of course
You have changed so many thing away from the stock specs there is no way the computer will adjust
http://www.pcmforless.com
has good reputation for online tuning
No
A stock TPI pump is a Hi pressure pump
How do you know it is running lean?
Have you put a wideband O2 on it or datalogged it to see exactly what the computer is seeing and doing ?
What is your fuel pressure?
With injectors that big on a stock tune it should be running pig rich everywhere
Engine: 5.7
Axle/Gears: 373
Re: help
Well when I finished putting the parts on I started it up and ran it for about 2 or 3 mins engine code 44 piped up and it showed symptoms of a lean condition like everything got hot to quick
Car: 82 Z28
Transmission: T400
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: help
I dont know anyone that has had luck using a thumper cam with EFI
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: 5.7
Axle/Gears: 373
