Will not restart when hot
Old Jan 13, 2014 | 07:06 PM
KLR2466's Avatar
Car: 1989 IROC-Z
Engine: 5.7 Tuned Port Injection
I have a 1989 IROC-Z and I just got it back out of the shop and now when I let the car run or drive it and the motor gets hot it will not start back up, have no idea what is wrong.
Old Jan 13, 2014 | 08:08 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Will not restart when hot
Do you have headers? How old is the starter? How 'Hot' is it getting? Will it crank at all? How long does it have to cool before it will fire again?
Old Jan 13, 2014 | 08:13 PM
KLR2466's Avatar
Car: 1989 IROC-Z
No Header's, and its getting to norm temp, it cranks fine when the motor is cold just if you shut it off after it is warmed up it wont restart until the motor cools back down, it doesn't run hot at all.
Old Jan 14, 2014 | 02:14 AM
Redchevy808's Avatar
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Try taking the icm out of your dizzy and testing it at your local parts store, those like to fail when hot, and symptoms are as you describe
Old Jan 14, 2014 | 03:26 AM
KLR2466's Avatar
Car: 1989 IROC-Z
Thanks will try to get to it tomorrow hopefully that is it.
Old Jan 14, 2014 | 06:17 AM
Does it crank hot?
Old Jan 14, 2014 | 06:28 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Is it turning over? Or is it doing absolutely nothing, maybe clicking? These kinds of details are important.
Old Jan 14, 2014 | 07:03 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Details will help us help you.
Old Jan 14, 2014 | 09:15 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
if it cranks slow it might be your alternator in least that was what mine was.
if it clicks try this fix https://www.thirdgen.org/solenoid might want to upgrade to a mini starter or a high torque one while your at it
Old Jan 14, 2014 | 05:21 PM
Car: 1992 Camaro RS
I had ZERO luck with a remote solenoid. Made absolutely NO difference. I will sell anyone the one I had for whatever they will offer me for it. I found it pointless. Thats more for heatsoak issues, which, by the way, were completely cured by a ministarter. More than that, he said he doesnt have headers. So it's probably not a heatsoak issue, at least not at the starter solenoid unless it's already going bad.
Old Jan 16, 2014 | 12:01 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
well my problem was caused by my alternator bearing heating up and being to hard for my starter to move. I suffered with what I thought was the so called heat soak issue but when It finally just siezed while the car was running resulting in a broken belt and one pissed of owner. No problems since and it starts up noticeably faster like the starter doesn't have to fight anymore.
Old Jan 16, 2014 | 06:21 AM
Edwardgp's Avatar
Engine: 454-350
Well that is one for the books. Have to put that on the list of things to check.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
