91 bird is having trouble starting, and white smoke is coming off engine, help!
Old Jan 26, 2014 | 07:16 PM
cam444sixpak's Avatar
Car: 91' Firebird "Em"
Engine: 3.1 V6
I have a 3.1 v6 with 350k miles on it. earlier today, it had trouble turning over, and after a few tries, i noticed white smoke coming out of the the sides of the hood. I panicked, opened the hood, and there was no fire, only white smoke coming from somewhere to the left of the engine block. Im stumped, does anyone know what this is and how to fix it?
Old Jan 26, 2014 | 08:02 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 91 bird is having trouble starting, and white smoke is coming off engine, help!
If you haven't already do a search on "white smoke". Check your coolant level. Check the condition of your oil. Sounds like you got a coolant leak in the engine compartment somewhere. Some folks say to pressure test your cooling system. I usually will try to visually identify the leak first while the car is running or just turned off after reaching operating temperature. Good luck.
Old Jan 27, 2014 | 02:42 PM
Engine: 3.1 V6
ok thanks.
bryan623
Mar 22, 2021 06:43 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
