help with cam selection
Old Jan 26, 2014 | 09:22 PM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
Here's my setup
-350 from a 93 1500 with stock internals 72k miles
ARP main and rod bolts
World product s/r torquer heads with mild port work
67 cc with 1.5 roller rockers
Perforer Rpm air gap intake
15/8 hooker headers
700r4 with a 3200 stall
3:73 gears in the rear.
Now I already have a brand new comp cam 270h cam installed but I'm wondering if ill be dissapointed with the over all power. The car is a weekend warrior that will see decent amount of track time. Mainly road racing and drag racing. Goals are at least 350hp to the wheels and I would love to break into the 12's with slicks . Do you guys think my cam is big enough?
Old Jan 27, 2014 | 06:26 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: help with cam selection
350 to the wheels is a pretty lofty goal for those heads, nevermind the cam.
What's the shortblock setup? type of pistons, deck clearance, CR/head gasket thickness? All that will determine IF it can even handle a bigger cam.
Old Jan 27, 2014 | 06:35 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
That block should have the 3 stud bosses in the valley so i would DEFINITELYswap that cam for a hhydraulic roller like the comp cams 503 or similar.
Old Jan 27, 2014 | 11:00 AM
1gary's Avatar
It might have the bosses,but if they are drilled and taped is a crap shoot.
http://www.crankshaftcoalition.com/w..._compatibility
Old Jan 27, 2014 | 11:07 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Those heads flow fairly well with some port work about on par with vortecs. You should probably be between 330-350 crank HP.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
