Replacing a Split Plug Boot
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Any tips or tricks for installing a new boot over the termination?
JamesC
JamesC
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Replacing a Split Plug Boot
If it's a daily driver, I'd replace the wire.
For something that doesn't get wet, I've put a few tight wraps of electrical tape around a split boot and never had a problem. As long as there's no metal within 1/4" of the split region, it will be fine.
For the moment, I'd prefer to replace the boot.
JamesC
JamesC
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Lube the terminal & wire about 1/4 inch above terminal with a lil bit of electric grease
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yup: dielectric grease is a necessity. Wouldn't hurt to make sure the boot is as warm as you can stand it; maybe drop it in boiling water for a coupla minutes right before starting.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I assemble all of my plug wires for the 86 T/A and our 67 Camaro and what he said has been the easiest way of doing it.
MSD custom length sets where the plug side is done and you cut, crimp and install the boot on the distributor side.
Well, crap. I was prepared for a battle, but if the swap, from beginning to end, took more than a minute, I'd be surprised. I used WD40, BTW. No boiling water either. I'm actually surprised.
JamesC
JamesC
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
last time I did some uni's I got fed up with the 90s and split them on purpose, a wrap of black tape and done.
straight are easy
straight are easy
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
