84' FIREBIRD V6 2.8L please help!!!
Old May 27, 2014 | 09:34 PM
paul hill's Avatar
Car is shutting off when i put it in reverse.if i do manage to get it on the road it will shut off when i either stopped at a red light or if i put it into park. Also misfiring and no get up with the acceleration. ive changed my fuel filters, air filter, vacuum lines, pcv, sparkplugs , sparkplug wires, rotor button, dis.cap, new catalytic converter and exaust pipe.now im just exausted my damn self.lol would these all be causes of the fuel pump, or is it something else?
Old May 27, 2014 | 10:53 PM
Solidusdonut's Avatar
Car: 84 Firebird
Transmission: Auto :/
Re: 84' FIREBIRD V6 2.8L please help!!!
Make sure your getting spark to all your plugs. Also double check the firing order and make sure your plug wires are ran right.
Old May 28, 2014 | 08:05 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
https://www.thirdgen.org/forums/v6/
Old May 28, 2014 | 08:41 PM
ex-x-fire's Avatar
When you say "shut off" you mean stall, right?
Make sure the egr valve is not getting vacuum at idle or low engines speeds (it might be stuck open). A bad egr solenoid could cause it to open too soon.
Make sure the ignition timing is set to 10*, follow the instructions on the emissions label. Make sure the timing advances when you rev it.
Old Aug 13, 2014 | 01:54 PM
paul hill's Avatar
Ive tried finding them but I can not find the firing orders anywhere
Old Aug 15, 2014 | 02:31 AM
Mayt13's Avatar
Car: 1989 Chevy Camaro IROC Z28
Axle/Gears: Stock
"The REAL answer is 1 2 3 4 5 6 firing order. And the cylinder numbering is opposite the standard, as the passenger side of engine cylinders are numbered 1 3 5 going towards firewall. And drivers side cylinders are 2 4 6 from front of car to firewall."
-Courtesy of yahoo answers
Old Aug 15, 2014 | 02:38 AM
Mayt13's Avatar
Axle/Gears: Stock
Sorry for Potato quality. Drew on phone
Edit: totally derped the first time I drew it haha
Old Aug 15, 2014 | 02:53 AM
Mayt13's Avatar
Axle/Gears: Stock
I think both the Chilton and the Hayes have a V6 section. It would be with picking them up. Ensure your vacuum is routed correctly. If you haven't don't it, replace the EGR (almost always a problem). Then time the motor and report back.
Good luck
Old Aug 15, 2014 | 03:02 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you don't pay attention well, there is a V6 section to the site, youll get 10X more help there. Not everyone reads outside their intrest.
64goatman
Sep 9, 2015 01:09 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
mm4tt
Oct 14, 2001 06:17 PM
Questor
Aftermarket Product Review
May 31, 2001 04:02 PM
