CODE 44 BUT DYNO SHOWS RICH
Old Jul 13, 2014 | 05:17 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
Hi all! Since replacing the injectors and fuel pressure regulator on my 91 TA with the 350 TPI it is setting a code 44, lean condition. Could have been setting it before the new injectors but not sure. I just had it on the dyno and if anything it showed that the car is running a tad too rich? Recently replaced the o2 sensor too. Any ideas as to what could be causing this? Thanx!
Old Jul 15, 2014 | 12:36 PM
THCARGUY's Avatar
Engine: 350 in both
Re: CODE 44 BUT DYNO SHOWS RICH
Don't know if this makes a difference but the check engine light will come and go and not stay on during the entire time while I am driving.
Old Jul 15, 2014 | 01:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What size injectors did you use?
Old Jul 15, 2014 | 10:57 PM
THCARGUY's Avatar
Engine: 350 in both
I went with the stock 22lb size. They are the reman Bosch 3s from Southbay.
PestilenceIV
Sep 11, 2016 12:53 AM
Jk_Under
Sep 8, 2015 08:13 AM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
RyanJB
Sep 2, 2015 01:27 PM
