Car shut off while driving, no power now
Old Aug 7, 2014 | 09:35 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car just shut off while I was driving home. The ignition has no power to it, no check engine light, wont crank over, no power windows or anything. Only the head lights work. It looks like a burned a wire I had run in the car off of my headers. It was powered 12v with key on. Does it sound like my ecm shorted out when this happened. All fuses in the car and under the hood are good.
Old Aug 7, 2014 | 09:53 PM
prostar3898's Avatar
Car: 91 camaro rs
Engine: 5.0 tbi
Transmission: t5
Axle/Gears: 342
Re: Car shut off while driving, no power now
Did you check the fuseable link down by the solenoid or I've seen some with it by the battery box
Old Aug 7, 2014 | 11:35 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
It doesn't have one by the solenoid. Just the ecm fuse near the battery.
Old Aug 7, 2014 | 11:45 PM
Joe Tag's Avatar
It sounds a lot like a fusible link burnt at the starter solenoid. Your 85 should have them.
Old Aug 8, 2014 | 12:50 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I'll check it out. I have innovative brand battery cables on it though. I think they only have the one spot for an inline fuse, which I checked and its not blown.
Old Aug 8, 2014 | 01:19 PM
Joe Tag's Avatar
You are totally misunderstanding what we are talking about. These would be the two smaller gage wires that bolt on the starter with the positive cable.
Old Aug 8, 2014 | 02:19 PM
Car: 91 camaro rs
Engine: 5.0 tbi
Transmission: t5
Axle/Gears: 342
There will be no actual fuse to check it'll look just like a bump in the wire like it was spliced at one time with key on make sure you have power on both sides with a test light
Old Aug 9, 2014 | 06:20 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah this sounds like something fundamental at the starter post to me.
Old Aug 10, 2014 | 08:35 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for the replies. I know what you mean now, I thought you guys were referring to the ecm fuse. It looks like it is bad. I'll get a new one and see how it goes from there.
Old Aug 10, 2014 | 09:11 PM
Iroc'd You's Avatar
Car: '89 Iroc-Z
Engine: LO3 305
Transmission: Automatic, Racing
Literally the same thing happened to me. Turned out to be the alternator. If anything just take yours off and take it up to Autozone to have them test it for you. With a core charge you should be able to get it for around 103$ Hope this helps.
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
