No start
Old Aug 10, 2014 | 07:29 AM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
No start
Tried starting the GTA yesterday morning. Fires right off when first turning key, then nothing. Engine will turn over as long as I turn the ignition key with no start after that. Come back 10 minutes later, turn key and fires off then nothing again. Hooked up battery charger after running battery down and it did this all day long.
Things I checked;
Fuel releases at Schrader valve on rail. Also hear fuel pump engage when key is turned on
12 volts on coil wire post with ignition switch on.
Out of ideas here. Any suggestions will be appreciated.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
