Rough idle at first start up
Old Aug 26, 2014 | 05:13 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Ok so I have a 87 gta trans am it starts up and runs but at first start it idles rough but when the car warms up it's ok runs fine. I do not have o2 sensors and I do not have a egr valve. I didn't take those things out I bought the car like that. The fuel pressure is at 50 with the vacuum line connected. I changed spark plugs but not the rotor. I have a msd spark box too.
Old Aug 26, 2014 | 05:15 PM
Engine: 5.7 350 TPI
Re: Rough idle at first start up
Also if the o2 sensors were disconnected wouldn't the engine light be on? Can I add them back if that would change the idle
Old Aug 27, 2014 | 03:49 PM
Oddie65's Avatar
Car: 1986 G92 Z-28
Engine: '89 L98 (5.7 TPI)
Have you checked you IAC valve? If its dirty or not functioning properly, it can cause all sorts of hell with the idle. As far as the check engine light goes, yes I would think the light would illuminate. It's possible that the bulb is just burnt out, but I've also heard of people tuning the memcal's so they no longer throw a code with something like o2 sensors disconnected. If I were you, and theres still a bung for the sensor, I'd put em on. There are numerous articles on here and from a google search on how to check/reset your IAC. I would start there, its simple and pretty much free.
Old Aug 27, 2014 | 05:45 PM
Engine: 5.7 350 TPI
Thanks so much for the reply.
I took out the idle air control valve and I plug led it in and turned the car on the ON position and the idle air control valve pintle didn't move. I felt a little vibration but it didn't move could that be the problem.
And about the o2 sensor the bung it not there it has a full exhaust
Old Aug 28, 2014 | 08:11 PM
Engine: 5.7 350 TPI
Anyone else with ideas?
Old Sep 16, 2014 | 03:52 PM
Oddie65's Avatar
Car: 1986 G92 Z-28
Sorry for the late reply bud, but yes if the pintle didn't move at all then your IAC is faulty. Without an 02 sensor it still may not run completely perfect, since that helps determine your a/f ratio, but as far as a rough idle the IAC will have a huge impact.
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Bradsaundry
Aug 12, 2015 12:34 AM
