Need Quick Help
Car: 1991 Trans Am Convertible
Engine: 5.0 TPI
Need Quick Help
So i started to work on my project car and like a dumbass, made a rookie mistake and didn't label or categorize what i took off. So if you know where any of these pieces go or what hooks into them, would take any advice. I had to change the intake manifold gasket.
Its a 91 5.0 TPI if that makes a difference
http://imgur.com/a/Yi2IH
Engine: 5.0 TPI
Re: Need Quick Help
Also if anyone could tell me or link to a pic of the order the spark plugs go on the distributor that would be great.
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
Re: Need Quick Help
The plugs are 1,8,4,3,6,5,7,2
On engine the driver side is odd cylinders, passenger side is the even
As for distributor , if looking at it from directly above the cap, #1 should be at like 5 o'clock then go clock wise to each cylinder.
Engine: 5.0 TPI
Re: Need Quick Help
Re: Need Quick Help
Np the 5 o'clock thing was meant if looking down on the dist cap from the front of the car. Hope the pic helps give ya an idea what I meant
Engine: 5.0 TPI
Re: Need Quick Help
Yeah i got that and it still wont start like it cranks but wont turn over its like its not getting fuel i think i dont have something hooked up right.
Car: 88GTA
Engine: 5.7TPI
Re: Need Quick Help
OMG... I love it!!! Just kiddin Vert.
Hang on, and here goes.
1st pic- Line goes to rear plenum port, drivers side, to brake booster
2nd pic- Fuel pressure regulator hose to rear of plenum, pass. side, small port
5th pic-Check valve connects to rear, pass side plenum port, should tee before check to go to heater hard line in harness by coil on fire wall, then to drivers side vacuum ball in fender.
6th pic- connect to connector on coil along with the pink/white connector, side by side.
LABLES ARE REALLY CHEAP. Try that next time! Kidding, but they do help!! Good luck!
Bob
Bob
Engine: 5.0 TPI
Re: Need Quick Help
if someone could post pics of their passenger engine bay with all the vaccum lines that would be great as a point of reference.
Car: 88GTA
Engine: 5.7TPI
Car: 1988 IROC Z coupe
Engine: stock LB9...for now.
Transmission: T5 non world class :(
Axle/Gears: BW with 3.73 gears.
Re: Need Quick Help
pic 1 is your vacuum line from brake booster to the back bottom of your intake plenum.
pic 2 is your vacuum line from your fuel regulator valve to the intake plenum.
pic 3 is your fuel regulator
pic 4 is your EGR valve.
pic 5 is a vacuum check valve that connects the charcol cannister and heater to the intake plenum.
pic 6 & 8 not sure... it looks like the pig tail that connects to a sensor under the intake plenum to the wiring harness at fire wall.
pic 7 looks like your EGR solenoid valve that connects to your check valve and to the bottom of you intake plenum near front driverside.
I hope this helps some. I am a newby myself, but just went through and replaced pretty much everything that you listed.
Car: 88GTA
Engine: 5.7TPI
Re: Need Quick Help
pic 2 is your vacuum line from your EGR valve to the intake plenum.
pic 3 & $ is your EGR valve.
pic 5 is a vacuum check valve that connects the EGR solenoid valve to the intake plenum.
Engine: 5.0 TPI
Re: Need Quick Help
Engine: 5.0 TPI
Re: Need Quick Help
So I think I got everything put back but it's still not starting, I think my timing is off. I marked the rotor when I took it out and replicated it when I put it back in, but every time I try to start it, it moves the rotor on its own and then it's way off does anyone know how to fix it?
Car: 88GTA
Engine: 5.7TPI
Re: Need Quick Help
Bring #1 up TDC on compression stroke, and look at rotor. Is it pointing to #1?
If not, pull dizzy and re-stab. And snuggly tighten dizzy holddown
Do you have spark?
Engine: 5.0 TPI
Re: Need Quick Help
The rotor is gonna turn, its connected to the dizzy shaft, which is turned by the cam. Does it try? Backfire? Are you sure you are in time?
Do you have spark?
Do you have spark?
Car: 88GTA
Engine: 5.7TPI
Re: Need Quick Help
You say no power??? Does it CRANK and Turn over??? If it turns over, you must have power. Pull #1 plug and have someone crank/bump. Engine over till it blows your thumb/finger off the #1 plug hole. Then look at dizzy after pulling cap and look at the rotor. Is it pointing at #1?? If not, pull dizzy and restab, replace cap and redo wires starting at #1. It has to start.
Car: 88GTA
Engine: 5.7TPI
Re: Need Quick Help
Look at balancer and after you finger pops of, it SHOULD be at zero. Rotate crank with socket to fine tune TDC. Then prceed with above
3.8TransAM
Sep 27, 2015 08:37 PM
