Crank but no start after battery replacement
Old Sep 7, 2014 | 10:31 PM
avgjoe's Avatar
I had to replace the battery. Due to reconditioning of the battery tray my 91 z28 F engine sat for 1 week. Everything works and it cranks over but no spark. What happened? Do I need to reset something. Ran fine before the battery replacement. Stumped.
Old Sep 7, 2014 | 10:53 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Crank but no start after battery replacement
What usually happens to me is when I replace a weak or bad part, another part that was marginal will give out. If you have no spark trace it back to the coil, ICM, or pickup coil and see if they're still running to specs. You can check the coil and pickup coil with a voltmeter. The ICM will have to be pulled and checked at an auto parts store. Good luck.
Old Sep 12, 2014 | 10:13 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
There an inline fuse right next to the battery that goes to the fuel pump, many times when people replace the battery they break a wire or connection going to the fuse causing the fuel pump not to kick on
Edit- just saw you don't have spark, disregard this
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
