tilt wheel, ignition switch, high beams, horn all broken. should i replace column
Old Sep 21, 2014 | 10:15 PM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
I just picked up a 1990 RS manual a few weeks ago and have been slowly working out the kinks.
The next problem i have on my checklist is the many problems the steering column has.
I am pretty sure this car has either been stolen or the owner lost the key once upon a time because the steering column has been ripped through on the left side.
Ok on to the problems:
Tiltwheel: there is a little pin with a hole for a screw in the middle of it that pretty much holds the wheel in place, it allows me to pull the lever and play with my tiltwheel, occasionally this pin will pop out and my steering wheel will be a floppy mess.
Ignition switch: in order for me to start my car, that tiltwheel pin has to be in place, aligning my steering wheel enough to where i can push on to this metal bar thing while turning the key allowing my car to start
Hi beams: my turn signal switch just freely moves back and forth, no hi beam action at all.
Loose wire and lose metal bar thing: i have a loose white wire that has an end for a connector i cant seem to find a home for. There is also a little metal bar that seems like i goes to the turn signal but i cant seem to find a proper home for it either.
Conclusion: with all these problems, will it be simpler to replace the entire steering column? Is there seperate pieces to the steering column, like a higher and a lower piece that bolts together to save me from having to rip the whole column out? I will have pictures up right now
Old Sep 21, 2014 | 10:28 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Re: tilt wheel, ignition switch, high beams, horn all broken. should i replace column
Pic 1 shows that metal bar, the one that kinda loops,i have to align that with a metal bar that has a groove on it while turning my key to startup.
Pic 2 shows me holding the metal "peg" that holds the steering wheel in place, when driving this "peg" will shoot out, without it the tiltwheel spring flings my steering wheel to the right kinda dangerous while driving. Without it i am also unable to align that metal bar from pic 1 thus keeping me from starting up
Pic 3 shows my finger on that metal bar i mentioned toward the bottom of my original post, you can also see the white wire at the bottom of the pic going off the camera... can find a home for these things
Attached Thumbnails tilt wheel, ignition switch, high beams, horn all broken. should i replace column-cam00685.jpg   tilt wheel, ignition switch, high beams, horn all broken. should i replace column-cam00688.jpg   tilt wheel, ignition switch, high beams, horn all broken. should i replace column-cam00690.jpg
Old Sep 21, 2014 | 10:29 PM
Car: 1990 RS Camaro
Engine: 305 TBI
For some reason the last 2 pics rotated sorry
Old Sep 22, 2014 | 12:28 PM
OrangeBird's Avatar
Car: 1989 Firebird
You pretty much answered your own question , but Hell Yea buy a good used column and go with that . Where you describe yours as having been smashed in on one side in attempt to circumvent the key , loose at the tilt mechanism , and with broken switches added in , a good auto recycling yard column will run ya maybe $100 to $150 . You'll need to deal with the Vats as it doubtful the replacement column will come with the correct key for your vats module but that still seems easier than fixing all you say is wrong with it now .
Old Sep 22, 2014 | 12:40 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You might luck out and find one with the key!
Old Sep 22, 2014 | 01:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Swap you key cylinder into the column you get, then you have the right key
Old Sep 22, 2014 | 09:10 PM
Car: 1990 RS Camaro
Engine: 305 TBI
To the yunkyard i go.. im correct in assuming the columns are universal throughout the various years of thirdgen camaros?
Old Sep 22, 2014 | 09:37 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
No they are not universal. Off hand here are some differences (but don't quote me):
  • 82-83 wiper motor differences
  • Later years include VATs which use resistor keys.
  • Manual vs. auto. I haven't seen many manuals though. Auto has a lock out for the shifter so I'm not sure if you can get around that.
Best bet is if you have local Upulls as they are cheaper. Some list current cars online w/ prices, and also offer guarantees. Patience is helpful as well.
Old Sep 23, 2014 | 12:45 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Thank you for that info. I do have a 90 with a t-5 which sucks cuz im sute there arent many t-5 maros out here in the junkyards but this problem is not keeping my car from running so although ill have an eye on every junkyard in san diego, i wont anticipate having a new column as I am anticipating a vortec 6000 or larger
Old Sep 23, 2014 | 02:25 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is my first Camaro and my column was the same way.
I absolutely love my tilt wheel, especially with a 13 1/2" Grant.
Just make "sure" there is "no" wobble at the tilt mechanism .It should be nice and solid or you will be digging into that column to fix it.
Old Sep 23, 2014 | 06:24 AM
OrangeBird's Avatar
Car: 1989 Firebird
If your 90 has an airbag , and if your required to not circumvent that airbag due to California regulations (pretty much universal among ALL states is that your not legally allowed to circumvent safety equipment on street cars) then you will need a column from at least 90 since 89 and prior had no airbag . As long as it's a 90 , 91 , or 92 it should fit and then all you'll have to deal with is the VATS .
Old Sep 23, 2014 | 06:33 AM
OrangeBird's Avatar
Car: 1989 Firebird
PS , you may want to do further research on this , but , I think it will be easier to use a column from an auto shift car in a manual than it would be to use a manual shift column in an auto shift car . Don't take this as gospel but I think I remember reading threads here of guys having to do just that , using a auto column in a manual car due to the far greater availability of the auto column than the manual one in the junkyards .
Good Luck with it
Old Sep 29, 2014 | 12:15 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
You are better off repairing the column you have. You have a three year only column and you have both vats and an airbag.
Vintageracer
Jan 10, 2020 05:33 PM
BBSDesigns
Aug 11, 2015 07:39 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
