FUEL PRESSURE GAUGE
Old Sep 28, 2014 | 10:11 AM
G_FORCE32's Avatar
FUEL PRESSURE GAUGE
My fuel pressure gauge has been stuck at 5psi for more than a day. Is this normal? If not then how do i release the pressure so that the gauge can drop back to zero?
Old Sep 28, 2014 | 12:51 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: FUEL PRESSURE GAUGE
It could just be residual pressure or it could be a bad pressure gauge. Does your fuel line have a pressure port (Schrader valve) that you could relieve pressure from? You could also unscrew the pressure gauge to see if the gauge drops to zero.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
