L98 350 issues.
Old Dec 7, 2014 | 03:28 AM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
L98 350 issues.
Okay the car starts just fine idles flawlessly sounds amazing. Put it in drive hit the gas runs like a bat put of hell, slow down and it dies. Let off the throttle at all and it dies. Does fire right back up though. My dad said he had to give it a little gas once to turn it back over but this is the strangest thing.
I have heard it could be the ignition module under the distributor cap. Potential fuel pump and or relays.
I'm just wondering if anyone else has has these issues or can suggest some other things to check?
Old Dec 7, 2014 | 04:22 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: L98 350 issues.
Check the voltage on the TPS. https://www.thirdgen.org/tpimod2
Old Dec 7, 2014 | 09:15 AM
Re: L98 350 issues.
Thanks, checked and working fine. It finally threw a code at me. Code 42 which works out to be the ignition module on the distributor. Will be getting that soon and checking again.
Old Dec 7, 2014 | 11:03 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: L98 350 issues.
I would also swap out the pickup coil while in there.
Use GM stuff.
Old Dec 8, 2014 | 11:54 AM
Re: L98 350 issues.
Use GM stuff.
I did, I bought a new distributor because it had the original distributor from 91 on it and the base plate was stripped causing the rotor to hit the cap and rub.
So I replace all the plugs, wires, coil, distributor and im still getting a code 42, im stumped guys I cant figure this one out. Its also not firing on all 8.
Old Dec 8, 2014 | 12:27 PM
TTOP350's Avatar
Re: L98 350 issues.
What brand of distributer did u buy?
Old Dec 8, 2014 | 12:37 PM
Re: L98 350 issues.
Advance auto parts tough one brand
Old Dec 8, 2014 | 06:23 PM
Re: L98 350 issues.
Ok got it on all 8 again but stil giving me code 42, there is nothing wrong with the motor though. it runs fine but the code keeps popping up.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Aug 31, 2015 06:04 PM
NBrehm
Aug 25, 2015 11:49 PM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
