View Poll Results: which roller rocker arms to use on my build
harland sharp alumninum roller rockers 1.5 3/8 stud used w/girdles
66.67%
name unknown steel roller rockers 1.52 7/16 stud new
33.33%
Voters: 3. You may not vote on this poll
aluminum roller rockers or steel roller rocker arms
I am putting back together my 358 sbc for the summer make some more runs down the track I cant decide which rocker arms to use I have a set of 3/8 stud Harland sharp roller rockers with stud girdles 1.5 ratio.. I also own a new set of name unknown full steel roller rocker 7/16 stud 1.52 ratio.. these will need a new set of poly locks to use my stud girdles on them what to use.....????? flat tappet hydraulic cam
Car: 1988 Camaro
Re: aluminum roller rockers or steel roller rocker arms
I have seen too many rocker arm failures to use any no name/unknown rockers.
I know and trust...
Harland sharp
Howards purple billet
Scorpion
Crane gold race
Comp cams ultra gold
Comp cams ultra pro
Crower enduro
Comp cams magnum
Elgin.
That's the only ones I would use.
What's your cam lift and RPM range?
I know and trust...
Harland sharp
Scorpion
Crane gold race
Comp cams ultra pro
Crower enduro
Comp cams magnum
Elgin.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've had both types. As long as the brand is good and using a high end version, it doesn't really matter which type you use. Inexpensive rockers are inexpensive for a reason.
On my original SBC, I had Crane Gold and Crane Energizer. When I broke a gold, I thought I could use what looked like an identical Energizer but found the size of the trunnion was smaller. The rockers looked identical in every way until you took them apart. Then you could see the differences.
On my BBC, I ran Comp Cams stainless rockers for years until I seized a few of them up. I now run T&D aluminum shaft rockers.
thanks for the responses so far this a .510 lift 245 degrees duration at 50 thousands cam...motor will run out to about 6800-And will be hit W/ 175 shot of NOS
Car: 1988 Camaro
The steel one looks to have some casting roughness to it. Any little places that are not smooth can become a stress point and crack/break. I would go with the harland sharps
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
The weight of the rocker arm also adds to valve train weight and you have to control it too. I would go with the lightest strongest rockers you can. Get some good aluminum rockers.
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
