fly wheel/torque converter making ticking sounds.
Just this past weekend I deleted my air injection system mostly because of all the exaust leaks it had..now im hearing a tick or knock from around the flywheel area. I replaced a lot of the vaccume lines that were bad including the shift module on my 1978 305 CID engine. Is there other vaccume lines I missed? Also I bought a new edlebrock air cleaner what do I do with the vac lines coming from the trans moduelator and the one from behind at the bottom of carb can I plug any especially the 2 nipple one on the intake manifold.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fly wheel/torque converter making ticking sounds.
Pull the inspection cove and make sure the flex plate bolts are tight and look for cracks in the flexplate.A ticking sound cold be a exhaust leak as well.
https://m.facebook.com/pages/Tuned-P...88567194688156
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Does this have an exhaust heat riser on the passenger side? They will do that sometimes, especially if vacuum to them is low or shaft is sticking.
Car: 1988 Camaro
A loose torque converter bolt will do it.
I bought one a while back cheap due to this. Man was selling it as "runs but engine knocks" I looked at it and it sure enough knocked but only in drive or R, not in park.
I bought it, got time to mess with it, got under the car and checked the converter bolts, 2 was loose. Tightened them and the knock in gear went away.
Also a cracked flexplate will do it.
Exhaust leak at the rear or bottom will too
1992 Trans Am
May 10, 2023 07:19 PM
