Odd wiring on Throttlebody
Old Jan 25, 2015 | 11:09 AM
88KyKITT's Avatar
I am working on getting this ole bird running smooth...and ive come across a number or odd wiring issues from the previous owner. This one has me scratching my head. He has a wire tied in on one injector, running to the other, as ive crudely shown on the image...and idea what he has done, or why? Removing it doesn't seem to change anything that i can tell.
Old Jan 25, 2015 | 01:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Odd wiring on Throttlebody
The injectors have a common power
Old Jan 25, 2015 | 02:00 PM
88KyKITT's Avatar
Not certain i know what you mean. I am trying to determine if this is something that he did to fix another issue, or what?
Old Jan 25, 2015 | 02:11 PM
Engine: Lb9
Transmission: M20
The white and red wires are hooked together to supply power to the injectors.
Old Jan 25, 2015 | 02:15 PM
88KyKITT's Avatar
theresd already power going to the injectors. the guy Spliced a wire into them...That is what i am trying to figure out
Old Jan 25, 2015 | 02:20 PM
88KyKITT's Avatar
https://www.dropbox.com/s/cc0dmzccfwwy2xu/20150125_151636.jpg?dl=0
Heres the Actual issue i am trying to understand. the extra wire comming from under one injector going to wire on the other
Old Jan 25, 2015 | 02:21 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
What Tuned is getting at is both injectors are supplied constant power with the key on. That's what he means by common power. The computer will control the grounds. My guess is the PO had no power going to them and he spliced a direct power wire into those two. Or the PO used those as a power source for something else which is pretty outlandish.
upon seeing the new picture, I'd say one injector had no power so he jumpered between the two. Exposed wires over gasoline.. that seems a little unsafe.
Old Jan 25, 2015 | 02:25 PM
Engine: Lb9
Transmission: M20
The power comes from the injector fuse at the fuse box through c100 to the splice at the white and red wire. Looks like there may be a issue at the splice or c100 or someone taped power from the injector power feed.
Old Jan 25, 2015 | 02:27 PM
88KyKITT's Avatar
With the wire removed, no change, at least not visable. the engine doesn run any different...so seems to still have fuel flowing properly. Im wondering if removing it would cause any issues, PO wasnt the shorpest tool in the shed, may very odd things done
Old Jan 25, 2015 | 02:38 PM
If the circuits are working well by getting the correct power and ground without the jumper wire, then I would look to redo those connections and continue searching for further problems elsewhere.
Ghettobird52
Jul 5, 2024 11:18 PM
armybyrd
Dec 5, 2015 09:22 AM
Warlocksirix
Sep 3, 2015 12:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
