Closed/open loop operation
Old Mar 6, 2015 | 04:07 AM
fenderman93's Avatar
How do i verify that my 1986 2.8l v6 camaro is going in to closed loop operation?
Old Mar 6, 2015 | 06:26 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Closed/open loop operation
Closed loop is based on Engine temp sensor and the O2 sensor operating properly.
Cold start up will default to engine warm up mode.. once the engine coolant gets up to temp the coolant sensor and O2 sensor will "tell the ECM" to switch to closed loop mode
which simply means the ECM will try to maintain a stoich A/F ratio until you go WOT based on default data programmed into the ECM by General Motors.
if all the sensors are working properly (no ECM trouble codes) then it should be fine.
Old Mar 6, 2015 | 10:02 AM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
you should be able to monitor the live data stream using something like WinALDL and an appropriate cable/laptop. It will also help immensely in diagnosing your poor economy to watch the live data stream.
Old Mar 6, 2015 | 10:28 PM
ok how to interpet on the numbers i see....where do i find the correct specs?
Fanatic1074
Oct 3, 2022 05:57 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Royal_Z
Sep 30, 2015 08:45 PM
luvofjah
Sep 26, 2015 08:28 PM
Formula8r89
Sep 22, 2015 04:24 PM
