injection system
Old Mar 13, 2015 | 03:51 AM
petrosky's Avatar
injection system
I have no injector pulse on one side only any ideas?I have power but no pulse changed ecm under distributor cap no change its a 89 firebird with 5.0
Old Mar 13, 2015 | 02:40 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: injection system
The ign module under the distributor cap would effect both sides of the injectors. There are two injector fuses. Better start checking wires. You didn't say if it's tbi or tpi but here are your diagrams. http://austinthirdgen.org/mkportal/m...ine_wiring.gif http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Mar 15, 2015 | 05:00 PM
southbaysd's Avatar
Car: 1990 Firebird Formula
Engine: 5.0 TPI
Hi, I think I may have this same issue, what is the effect of this on the engine? Does it run rough? Have you noticed if one side is running cold?
Here is mine
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
aharvel50
Sep 21, 2015 07:31 PM
