88 Firebird 388 Carbed. Want to delete ECM.
Old Apr 9, 2015 | 12:40 AM
Jbaum's Avatar
Car: 1988 Firebird Formula
Engine: 388 Stroker
Transmission: BW T-5
Axle/Gears: Moser axle 3:55
Like the title says, I have a 1988 Firebird Formula, it has a 388 stroker carbed in it with a BW t-5 tranny. I want to take the ECM out with all the wiring under the hood without just butchering the harness. I know the speedo and other gauges wont work if I do that and I haven't found any good resource for how to get around this problem. I don't really car to keep the stock gauges because I plan to make this into a street/strip car, so im probably going swap all of them anyway. Does anyone know what I would need to do to get the VSS to wire up straight to the gauge and the other gauges as well. Im not a beginner mechanic, but with this I am. For instance...can I run the wiring from the VSS straight to the new speedo or does it go to the computer to "process" the signal and then send a signal to the speedo. Any help is appreciated. Pictures will come soon.
Out-Cast
Aug 22, 2015 07:49 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
djmarch
Aug 19, 2015 12:07 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
