Best way to jack up the rear end
Car: 1986 Camaro Z28
Engine: LB9
I'm planning on changing the fuel pump in my 86 Camaro and I'm wondering what the best way to do it is. I would much rather have pictures explaining the process as well.
Last edited by that1guy24; Apr 24, 2015 at 03:10 PM. Reason: Forgot to add something
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: Best way to jack up the rear end
its a big pita in our cars you have to drop rearend to drop tank isnt to bad if your rearend has been out but if its the factory and never been undone be prepared to replace broken bolts i broke three the first time i done one many people with fab skills will just cut a hole above the tank and make a door for it ive done this but dont recommend to any one to cut holes in there car
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Place jack stands as far rearward as possible just in front of the lower control arms. Be sure to chock the front wheels really well before you start.
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Place a floor jack under the center of the rear end and jack the car up as far as the jack will go, then do
Then use the jack to lower the rear end for tank removal......
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
