timing advance how does it work?
Old Jun 18, 2015 | 06:17 PM
Jonny45's Avatar
Car: 1988 Firebird
Engine: Built 3.4 swap
Transmission: worldclass T5
Axle/Gears: 3.23 28 spine posi with moser axles
Im guessing its in the ecu?
How much does it bump up and what rpm and can it be changed?
I figure someone should have a good answer...thanks guys!
MPFI v6 in a 87
Old Jun 19, 2015 | 03:06 AM
Vader's Avatar
Re: timing advance how does it work?
Your guess is correct. Timing is controlled by the ECM, and the tables can be changed. A quick look around the DIY PROM board should provide an overview of how.
Timing can be set to advance up to 50° BTDC and at various RPM and load levels.
Old Jun 20, 2015 | 05:13 PM
Jonny45's Avatar
Car: 1988 Firebird
Alright thank you sir!
armybyrd
Dec 5, 2015 09:22 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
