At a loss
Old Jun 25, 2015 | 11:34 PM
Dustin250r312's Avatar
At a loss
Okay I have a 89 camaro tpi 350 I took it for a long drive today and ran perfectly fine but then when I went to go start it and drive it again it would barely want to take off pedal to the floor and just sounds like it wants to die out but the rpms will idle fine if in neutral just when in gear it will not want to take off or go at all I'm at all loss changed distributor,plugs,wires,ECM and put the timing in the correct order any ideas with be great thanks
Old Jun 26, 2015 | 10:23 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: At a loss
How's your fuel pressure? Check your TPS also.
Old Jun 26, 2015 | 08:30 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: At a loss
Vacuum leak, fuel pressure
Edit: also check tps volts and idle air control and make sure they're within spec.
Old Jun 26, 2015 | 10:49 PM
Re: At a loss
Couldn't find any vacuum leaks but my tps is all good and now it has a lifter knock when I try to drive it and only does it when it's in drive or reverse but got a check engine light on for my egr valve also thinking that's the problem with the misfire kinda? But at a loss on the lifter knock now
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
