1985 Trans Am LG4 Passed Ca Smog
1 Post
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Just had my car inspected and passed the enhanced smog test with flying colors. Nox readings at 15 and 25mph were 10ppm. That's correct; only 10ppm! Let me be clear that my car is completely stock right down to the EFE valve. I had a new catalytic converter installed two years ago when I failed for high Nox. The only niggling little problem I had was the gas cap. It failed to hold pressure and the tech replaced it. I'm not certain that it is the fuel here in SoCal, but the O-ring seal does not last long. I could see that there were cracks all around the seal. When I got back home, I removed the seal, flipped it over, and re-installed it. I also smeared a little petroleum jelly on it to keep it lubricated. Just wanted to share and let folks in California know that it is possible to pass the emissions test with a 30 year old car.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: 1985 Trans Am LG4 Passed Ca Smog
Awesome to hear. Mine is bone stock 89 350 TPI and I passed smog after the basic tune-up stuff and new cats. Flying colors, too.
AkDrifted
Exterior Parts Wanted
02-03-2019 04:19 PM
Slash
11-17-2015 11:54 AM
