Fuel smell
Old Mar 11, 2016 | 11:24 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Fuel smell
Looking for some advice on my 305 tpi.
I passed a friends camaro and he had the windows down. I gave it some good throttle and he said when I passed it smelled like straight gas. And I noticed it when I idle a long time, but I especially noticed when I reved it in park. No noticeably poor fuel economy, ses only comes on on start up due to the egr and blow by on cold starts. Doesn't blow any smoke. I'm pretty sure the cat is toast though, would that cause the smell? No noticeable leaks. The smell is more prevelant when warm
Old Mar 12, 2016 | 07:01 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: Fuel smell
Check the Fuel filler tube to tank connection for leaks, and the tank vent valve on drivers side by the tank.
Search for:
10029752
alt 10033125
alt 10245442
which are different partnumbers for basically the same vent.
It is often missing or broken.
Hope this helps
Old Mar 12, 2016 | 10:05 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: Fuel smell
I will look at the fuel filler neck! Thank you for those part numbers! If it turns out to be that vent, will it cause any other trouble if I don't replace it?
QUOTE=HasseO;6016275]Check the Fuel filler tube to tank connection for leaks, and the tank vent valve on drivers side by the tank.
Search for:
10029752
alt 10033125
alt 10245442
Hope this helps[/QUOTE]
Old Mar 12, 2016 | 11:35 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: Fuel smell
I dont know. Im thinking maybe its a bit dangerous to have fuel evaporate from the tank(fire hazard?''). Maybe You will loose a small amount of fuel, idk.
I replaced the vent and got rid of the smell. There is now a slight surge when opening the filler cap, which is how its supposed to be. The vent is 2-way, opening when You have spent some fuel driving, to relieve the underpressure, but also opening to relieve pressure build-up if needed.
My native language is swedish, but I hope my words make sense.
I didnt have any driving issues without a working vent, just the fuel smell.
Old Jun 14, 2016 | 01:20 PM
olivermeyr's Avatar
Car: 1988 Camaro Base, T-tops
Engine: 305 5.0 V8
Transmission: Borg-Warner 5 Speed Manual M5,A4
Re: Fuel smell
[QUOTE=apie2546;6016318]I will look at the fuel filler neck! Thank you for those part numbers! If it turns out to be that vent, will it cause any other trouble if I don't replace it?]
Did this end up working out for you? Same problem with my 88 TBI 305
Old Jun 14, 2016 | 03:01 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: Fuel smell
Hello,
Well You really need a working tank vent, and the smell is almost gone. There has still been some fuel smell during really hot days, but just a few times. I also replaced all the hoses going to and from the canister, to the throttlebody and the valve leading to the evap system(its connected to a metal pipe leading to the tank and a little hard to reach).
So replace hoses and fuel vent valve, it definitely helps!
Old Jun 14, 2016 | 03:15 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Fuel smell
Ive had this problem and fixed it replacing those hoses to the canister and replacing the canister itself.
Amy Marques
Nov 20, 2019 11:24 AM
Carystone92
Apr 21, 2016 06:08 PM
bop11
Mar 24, 2016 09:34 AM
joleda
Feb 22, 2016 08:50 AM
rusty vango
Feb 12, 2016 08:47 PM
