Help identifying missing accessory
Old Jun 22, 2016 | 04:09 PM
MotoCARR's Avatar
Car: 88 RX7
So I have a 305 from an 88 Firebird in my RX-7. Not new to cars but relatively new to GM powerplants. Anyone know what goes/is supposed to go in the bracket with the yellow arrow? I was thinking AC compressor but from what I can tell it sits higher based on google images
Old Jun 22, 2016 | 04:13 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Help identifying missing accessory
Smog pump. The AC compressor goes right above it where the delete pulley is now filling it's spot
Old Jun 22, 2016 | 04:16 PM
MotoCARR's Avatar
Car: 88 RX7
Ahhhhhh ok, thanks for the info!
Old Jun 22, 2016 | 08:23 PM
MotoCARR's Avatar
Car: 88 RX7
Is there a way to keep the serpentine system but get a different or lower tensioner? As you can see it's the previous owner cut a hole in the hood because of it lol
Tensioner pokes through the hood lol
Old Jun 22, 2016 | 08:45 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That's pretty much the only tensioner that fits the system. Putting together a bunch of different parts not designed to work together is going to produce challenges such as this. Looks like a few interesting coolant routing issues are going on as well. Good luck with it.
Old Jun 22, 2016 | 08:55 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That "ear" on the top of the tensioner, with the square hole cast in it, is for releasing the tension on the belts, to make changing it easier / possible. You put a 1/2 drive ratchet in that square hole, and use the ratchet as a lever to pull against the spring in the tensioner.
If you were willing to accept that changing belts / releasing that spring tension is going to be a bear without it, you could cut that ear off.
Old Jun 22, 2016 | 09:27 PM
MotoCARR's Avatar
Car: 88 RX7
Yeah I figured it was a long shot. While the car does run and drive, I definitely have some rerouting to do to make it more efficient/cleaner
Old Jun 22, 2016 | 09:32 PM
MotoCARR's Avatar
Car: 88 RX7
Thanks for that info! It definitely would have taken a while to figure out how to release the tension lol.
While a good idea, now that I look at the picture better it's a little deceiving in that more of the tensioner is sticking up though the hood. Couldn't get my phone low enough to capture it. The whole "ear" and spring portion would have to go/move.
86ZRESTO
May 21, 2018 08:33 AM
HEFF16
Apr 1, 2016 08:18 PM
gt4373
Mar 31, 2016 11:10 PM
ARthe1
Mar 31, 2016 10:38 PM
xbmx89
South Central Region
Mar 29, 2016 02:14 PM
