What you think?
Old 05-10-2017, 10:21 AM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
What you think?
Purchased an 89 IROC 350 TPI and restoring. I started to yank the block and when I pulled the valve covers it looked very clean. Then I yanked the intake and very clean again. I tracked down the prior owner and he claimed it was rebuilt. So I put a camera in the cylinders and can see the cross patterns and the gaskets on the heads and pan appear change. Can't really verify the bottom end going down as far as I did. I already put it all back together with new injectors and rail seals etc.. Looking at the cross patterns they look very fresh. What you think by the pictures about mileage that could have been on the engine after rebuild. I sort of took a chance and it runs perfect. I just pulled up enough to clean and paint the block since it was not painted. I guess I will never know for sure if it was completely rebuilt. Why you would rebuild one and leave the engine unpainted I have no clue.
Old 05-10-2017, 11:38 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: What you think?
Rebuilt replacement, most likely. Those aren't TPI heads.
If we had a clear pic of the top of the pistons, or you had measured the cylinder walls, that may have told whether the cylinders had been bored oversize.
Old 05-10-2017, 12:09 PM
GeneralDisorder's Avatar
Re: What you think?
The cross hatch pattern angle looks a little on the flat side. Probably a dingle ball job. People never move them fast enough. If it has good compression, good oil pressure, and doesn't smoke - WOT.
GD
Old 05-10-2017, 12:11 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: What you think?
Yup TBI 350 14102193 heads looks nice though. If it runs well leave it and enjoy.
Old 05-10-2017, 12:22 PM
dmm3369's Avatar
Engine: 350's
Re: What you think?
The block number is 14093638. I noticed the head numbers but could not find anything saying if they used those with TPI or not. Not sure what I lose with these heads. I really just want a good driver and not really after a load of HP.
Old 05-10-2017, 12:25 PM
dmm3369's Avatar
Engine: 350's
Re: What you think?
GD
Thanks, yea the compression is spot on and the oil pressure is good. I assume with them being so visible that is was not to many miles since rebuild.
Old 05-10-2017, 12:34 PM
dmm3369's Avatar
Engine: 350's
Re: What you think?
Thanks for the reply's. I'm just turning this one into a driver and going over everything to just have a solid dependable fun old car. I am just looking for a feel good about going with what I saw that is was rebuilt at some point. I love these cars! I spent so much on my 83 I am scared to drive it for the fear it will get hit. Not looking for HP just dependable. I am one of those people that starts rethinking stuff.
David
Old 05-10-2017, 01:48 PM
midias's Avatar
Re: What you think?
David
If it runs good it is good, change the plugs, filters and leave it alone just drive.
Old 05-10-2017, 06:27 PM
five7kid's Avatar
Engine: LS1/LQ4
Re: What you think?
That's a pretty common block. I had one that was a ZZ3 crate motor. It was a 350 block, and they dressed them up a bunch of different ways.
If you just want a good driver and not a load of HP, the 193 heads theoretically would be a good match with TPI (although the factory never did it). They share a sweet spot. I was just pointing out that the claim of a "rebuild" suggests the original engine was rebuilt, while the heads tell you at least they are not from the original build. But at least it still has roller lifters.
Old 05-10-2017, 07:33 PM
dmm3369's Avatar
Engine: 350's
Re: What you think?
Thanks! - David
