Engine Combo Thoughts and Suggestions - Cam Selection
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Engine Combo Thoughts and Suggestions - Cam Selection
There is some hp in a 3.5" catback vs a 3" at thr 500 hp level imo. All the latemodel cars i see in the 400-550 range def seem to show better results
A good flowing muffler in a single 3" can be used for what you are doing but consider a bigger system down the road or a cutout at the y.
2.5" y pipes should be ok for you
Car: 1987 Trans Am
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
I haven't seen any for the 700R4 except for custom jobs.I think I read somewhere that a 4l60e swap crossmember will fit the 700R4 with some minor modifications, though.
In regards to exhaust, with a cam & head swap I doubt you'll see much advantage with a 3.5" cat-back.
Car: 1987 Trans Am
My mods will include cam, heads, on a 383
Car: '84 Trans Am
Engine: 357 SBC
Ah, sorry. I missed the post with you switching your crank, too. I guess it all depends on what your goals are, and what they're worth. You'll hit a point of diminishing return. A 3.5" Mufflex is around $800. Everything else that's decent is about $400-500 for 3". Is the $300 worth 10-15HP to you? It's ultimately up to you and your wallet to decide.
Car: 1987 Trans Am
The 3.5" is probably not going to be worth the cost for the minor gains I would see however I am trying to find out what my options are as far as the longtubes headers go.
So far I have found hedman headers 68460 and the eBay knock off stainless steel sets.
Is a modified crossmember like above a necessity with these or can I get by with a standard crossmember and sacrifice the ground clearance until I can buy or fab one with the exhaust clearance?
Car: '84 Trans Am
Engine: 357 SBC
You have a few options.
1) A "double hump" crossmember that will allow you to tuck up your header extensions\y-pipe.
2) Route your Y-pipe to the outside of the crossmember. This will gain you some clearance, but not as much as going over or under a modified crossmember.
3) Run under the crossmember. This is the most straight forward and least expensive, but you do sacrifice some ground clearance. If your car is lowered it might cause issues. If it is not, most people do not run into issues (within reason).
Car: 1987 Trans Am
My car is not lowered at all and I don't have any plans to really do so. If there is enough room to run under the crossmember I will likely do that and possibly go back later if I need to modify it and tuck the pipes up higher.
Any pictures of the pipes using the stock crossmember to show ground clearance? ( non lowered cars )
Car: 1987 Trans Am
Still looking at parts for this build that I will be working on over the winter months. Any difference in fitment between the Headmann 68460 or the "eBay" stainless headers
