Just got my *** kicked by a stock 97 Blazer 4X4 w/ a V6 TWICE
Old Jan 1, 2002 | 04:34 PM
Black84Z28's Avatar
First we raced from a stop. We went on the 3rd beep of his horn and I got the jump but the Blazer just walked right past me and got at least a car length on me before we had to slow down(we were running out of road). I didn't even get out of 2nd gear that time though so I said let's go again on a longer road. So we went and found a longer road to race on and we went from a 40 roll. I got the jump again but he just pulled right past me and put 2 cars on me and kept them utnil I got half way through 3rd and started pulling up. I got up to about his bumper and then had to shut down because the road was coming to an end. I still can't believe it. I knew my car was slow as crap but I didn't think it was THAT slow. Is there anything not so expensive I can do to my car that will allow me to beat him next time? The car is a stock 95k mile 84 Z28 w/ an LG4/A4 and 3.23 gears.
Old Jan 1, 2002 | 04:49 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
that's just a plain embarassment to f bodies. you deffinitly need to improve before you race him again. both mine and my cousin's LG4 camaro's ran 15.61 and 15.64 with only cat back change, some adjustments to timing and carb, and a 3.08 open rear. if yours is running that slow, you may want to run a compression check on it. a big improvement i've found that's easy is going with a cooler thermostat and moving the timing up. you can find some slightly smaller metering rods for the secondaries to give it a bit more fuel also without alot of money into it or time.
Old Jan 1, 2002 | 05:15 PM
Jester's Avatar
I might have predicted that honestly. Stock vs. stock, the 97 4.3L is a much better performing engine than an LG4. True it's in a heavier vehicle..but still. Time to start modding that thing
Old Jan 1, 2002 | 06:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Headers and a cat-back (get the Hooker), soundclips are in my sig.
Old Jan 2, 2002 | 11:15 AM
pygmalion's Avatar
I can't believe that happened, my friend has a 96 stock blazer... we raced and he was way behind me. I didn't even bother to look back at him. It's definately time to do some modding.
Old Jan 2, 2002 | 11:42 AM
CODY BEHNKE's Avatar
Blazer 4.3's are quick but my 1995 S-10 SS is faster, In pick up form the Vortec 4.3 hauls A$$ stock (15-15.5 in the 1/4) Plus mines modded hopefully 14.5-15 in the 1/4
Old Jan 2, 2002 | 12:49 PM
85transamtpi's Avatar
Sorry Cody, but all the 4.3/5speed powered s10's I have seen at the track run low 16's. The blazer is probably a high 16, low 17 second car.
black84...
Something is wrong somewhere. There is no way you should loose by that much to a car that has 190hp and probably close to a thousand pounds on you. Check compression, timing, vaccum lines, and carb. 95,000 miles shouldn't have killed the LG4...but if it was abused who knows.
-peace
Old Jan 2, 2002 | 12:55 PM
Momar's Avatar
Were the S-10s that you saw at the track the SS' or just normal 4.3 powered, because I have heard that there is a lot of differrence.
Ben
Old Jan 2, 2002 | 01:07 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Back in 1986 I bought a brand new TA with a TPI. One day while cruising around, I was at a stop light next to a Suburban. The road was a 2 lane that merged into 1. We both hammered it off the line and I could not pass him. I was so embarassed that I vowed to do something about it. The first thing I did was put a NOS kit on it. What a difference! It felt like I had nitrous on the car? Oh yeah I did! Anyhow after becoming like a coke fiend on the NOS, I decided to go with a larger motor.
My suggestion to you is: either put a quick fix on the car like NOS or buy a Chevy crate motor. Crate motors are pretty affordable these days.
www.geocities.com/dzperf
Old Jan 2, 2002 | 01:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
lol the 4.3 blazers are slow but I can see him beating you from a 40mph roll because that blazer will downshift into 1st and pull till redline from 40. What condidtion is your engine in? I would run a compression check and then do a tune up. I beat a 99 blazer with my old 86 blazer 4x4 with a new 3.4 GM HO crate engine (that sucked). Prepare to laugh you butt off but when I first got my Z28 it was stock and a geo storm handed me my butt from a dead stop until 60 and I had 3:42 gears.
SSC
Old Jan 2, 2002 | 02:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '84 LG4 had a grand total of 150 ponies. The exhaust is very restrictive, as is the stock air cleaner. Fix those two things and you'll get back at least to his front tire.
The '84 LG4 also had a fantastic 8.6:1 compression ratio. Although you'd gain a good bit of power going deeper into the engine (cam, heads), it'll be limited from its potential without getting flat top pistons in it. If you go that far, you might as well get the perverbial 350 in there.
I'd be willing to run him, though...
Old Jan 2, 2002 | 02:32 PM
Z28DJP1987's Avatar
That is something I would NOT admit too. Beat by a TRUCK ...l
Genopsyde
Oct 7, 2015 08:35 PM
fasteddi
Sep 2, 2015 10:29 AM
InfinityShade
Aug 22, 2015 08:00 PM
overdriv
Aug 20, 2015 03:52 PM
ezobens
Aug 19, 2015 10:29 PM
