Timing tab issues
Car: 1986 Camaro Z-28
Engine: 350 Chevy crate
Transmission: automatic
Timing
I hope someone can help me,I have a 350 crate motor and had a to reuse the original harmonic balancer due to pulley alignment.The shop used the older timing tab(2:00 position) and my 86 Camaro use the 12:00 tab.Does anyone know how can I fix this?Im thinking timing tape but don't know where to put it.Open to any suggestions other than removing the balancer,Thx in advance
Re: Timing tab issues
If you can observe the keyway in the crank snout, that is in line with the #1-2 crank throw TDC. You can static time the engine using that as a guide then install the timing tape so that the indicator shows TDC wherever your timing tab might be. In other words, align the keyway perpendicular to the block deck for the left bank and install your tape accordingly. You can check the absolute position of the #1 piston TDC by removing the spark plug and inserting some sort of feeler, like a drinking straw (nothing that will damage the plug threads or piston top).
With a stock timing chain cover and stock timing tab, the TDC groove in the outer hub of the balancer is (according to my closest measurement) 7° retarded from the broached keyway in the balancer hub for the older style timing tabs.
can you use a 12 o'clock pointer? might have to trim the 2 o'clock one off?
https://www.summitracing.com/parts/m...e2-_-mr-gasket
Thx for the info guys,I was trying to fix it the quickest way without having to remove items,like mounting a timing tape correctly using the mark on the harmonic balancer as a reference.Might have to ordered the correct tab and install.
