Help on Engine gasket set
Old Dec 5, 2017 | 01:24 PM
Camaroguy2's Avatar
Car: 1991 Camaro RS
Engine: TBI 305 soon to be a TPI 350
Axle/Gears: 3.23 Gears
im going to be starting my engine rebuild hopefully soon and trying to price things out I’m trying to find all the gaskets I’m going to need in one kit. I have a L98 I will be putting afr 195 heads on it with the Edelbrock super victor intake manifold and making it carbureted if you guys could give me a part number for the felpro gasket set for this it would be very apperciated thanks in advance
Old Dec 5, 2017 | 05:52 PM
Re: Help on Engine gasket set
HS7733-PTx (whatever x they're up to now, last time I bought one and paid any attention to it, it was a 9, probably a much higher # now)
You'll probably want to get intake gaskets separately; use whatever AFR says is the correct fit to those heads. Probably 1204 or 1205.
Old Dec 5, 2017 | 06:05 PM
Ja85z28's Avatar
Axle/Gears: 4:10
In addition to the suggestion above, consider using the Fel-Pro 1 piece pan gasket.
Cometics makes excellent gaskets, but they're pricey.
Good Luck
Old Dec 5, 2017 | 07:59 PM
GeneralDisorder's Avatar
Cometic would be my choice as well. We use them extensively.
GD
Old Dec 6, 2017 | 05:04 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Kits are convenient only if you have a stock build. In addition to buying intake gaskets separate, you should buy the head gaskets separate as well. Your piston to valve clearance, quench, compression ratio, cylinder bore, and aluminum cylinder heads will dictate your head gasket choice.
Old Dec 7, 2017 | 08:42 PM
Camaroguy2's Avatar
Car: 1991 Camaro RS
Thank you for all you’re guys help
Old Dec 7, 2017 | 08:44 PM
Ja85z28's Avatar
Axle/Gears: 4:10
You're welcome and Merry Christmas
