Retrofit roller lifters
Car: Camaro RS
Engine: TBI 305 H.O
I have a 350 block but I'm bored 30 over and is now a 355 I'm using a hydraulic roller camshaft in the block is from 1987 so it came with a flat tappet camshaft so I have to use retrofit hydraulic roller lifters and have read varying reviews on the quality of many of those lifters so I would like to pick your guys's brain about which one is best
Re: Retrofit roller lifters
I have had good luck in the past with howards retrofit lifters i believe this is the PN but have to look up when I get home they are made in the USA and seem durable and quality
https://www.summitracing.com/parts/hrs-91164n
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Crower HIPPO
https://www.crower.com/lifters/hydra...odel-9319.html
However, without knowing anything else about your engine, all these choices given are probably well out of your price range. Just buy a full set from Comp Cams or that set of Howards lifters.
Crower HIPPO
Morel/howards street series are about the best you can get for a budget and mild cams imo. Still aint cheap but is what it is. The johnsons stuff is very nice too but alot more money
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Car: Camaro RS
Engine: TBI 305 H.O
Sorry I believe I got the year of the block wrong I think it might have been in 84 I'm not sure because this was my cousin's motor but I know it didn't come with roller lifters or the retaining plate in the front of the block for the cam
To support the suggestions above, for an average street build, and using Summit Racing as a parts source, any of these would do the job.
This is taking into consideration the need for a retro-fit type lifter and keeping costs down.
Don't forget you'll also need some way to control cam movement via a thrust button.
https://www.summitracing.com/int/par...make/chevrolet
I've used Comps entry level lifter in a few builds with no issues. As the engine became more aggressive, I made the switch to a tool steel bodied short travel lifter.
377Z
03-31-2004 07:46 AM
