Motor Mount Problem
Old Jan 5, 2002 | 09:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Motor Mount Problem
I just intalled new ES Poly mounts and when I lowered the engine the bottom tabs are in contact with the plate but the rear tabs dont even touch. They are like (inside) the tabe rubbing up against the inner wall. I have installed these correctly like the paper said and everything. Is this normal? I looked at the stock one on ther other side and it looks as if all the tabs are touching. Did I do soemthing wrong?
Old Jan 5, 2002 | 10:28 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
sounds like you put them in backwards in the clamp
if you look at the mount one tab is higher than the other
they go in a certain way .........it will also take a bit of trying to get them to set right if they are in the right way
I would just check them for the position in the clamp ...........but you said you did
so it will take a bit of positioning and moving to get it right
Hope that Helps
Old Jan 5, 2002 | 10:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yea they are in right I double and even triple checked. I am going to do the other side tomorrow to see whats up.,
jhawkeye
May 25, 2022 06:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
