Grinding after new starter installed???
Engine: 5L TPI
Transmission: WCT5
Finally got my starter rebuilt and back in the car just to have my excitement stomped by this terrible sounding grinding/scraping noise. It ran for a few minutes as it should and then the noise started, and it only makes it at idle. Anyone have any ideas?? My car’s a 5L 5 speed.
Re: Grinding after new starter installed???
I'd be taking that starter back out and having a close look at the gear , if it's chewed up you likely didn't shim it properly when you reinstalled it . And yes , even if it's the same starter , having had it "rebuilt" which usually involves replacing the "bendix" (overrunning clutch) , does indeed require the "shimming" process (setting the gear clearance) to be done as if you were setting up a brand new starter in it . Thread Starter
Engine: 5L TPI
Transmission: WCT5
I'd be taking that starter back out and having a close look at the gear , if it's chewed up you likely didn't shim it properly when you reinstalled it . And yes , even if it's the same starter , having had it "rebuilt" which usually involves replacing the "bendix" (overrunning clutch) , does indeed require the "shimming" process (setting the gear clearance) to be done as if you were setting up a brand new starter in it .I also noticed that it’s only sometimes that it makes the noise. Took the car to the gas station and back earlier today and it was perfect, then I started it again and the noise was back. If it needed to be shimmed, wouldn’t it be constant?? The starter’s definitely tight enough so it isn’t moving around. Also, I’ve never done this before so how do I shim it??
Glowsock
Jul 10, 2015 06:43 PM
sogabe
Aug 17, 2006 02:06 AM
breathment
Aug 18, 2002 09:14 AM
sdevine
Nov 4, 2000 03:59 PM
