24502586 hot cam
Car: 92 z28
Engine: 5.7
Transmission: t56 6-speed
Axle/Gears: 3:42
24502586 hot cam
I have a 92 z28 with the 5.7 TPI I would like to put this cam in but I am worried it will affect my power brakes. Did anyone that did this have any problem with vacuum? thanks
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Re: 24502586 hot cam
A Hotcam with speed density? I would search here and ask to see if SD will run good.
The brakes will be fine. Are you planning on running this cam in a stock motor? SD will require tuning
IrocRoadRacer
08-22-2014 04:31 PM
Lestrey08
07-01-2009 05:00 PM
RoadRocket L98
Aftermarket Product Review
02-19-2001 01:35 AM
