starting problems
Old Sep 9, 2018 | 10:47 AM
paul1805's Avatar
starting problems
87 gmc dual tank 5.7l tbi short bed truck.well i can get it started using the fuel pump priming wire.when i unhook it it will stay running.when i go to restart it it just turns over and that's it.i can hear the fuel pump run when i turn the key on.help it has new fuel pumps in both tanks,i changed the fuel pump relay also.any help would be so much appreciated thank you
Old Sep 9, 2018 | 06:37 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: starting problems
could see if any fault codes are stored in the ECM-jumper a+b on the diagnostic plug under the dash and watch the "check engine"light flash sequences for the codes.I don't recall if these trucks have a wire from the crank terminal on the starter to the ECM to tell the ECM a start attempt is being made-if there is a break in that wire,could cause hard starting ?
Old Sep 10, 2018 | 12:56 AM
paul1805's Avatar
Old Sep 10, 2018 | 01:08 AM
paul1805's Avatar
thank you very much for reply back,but i think i have it fig out .i bypassed the porting vlv for the two tanks.then tried to start it and got no fuel at the inj's.so i tried it by plugging in a power wire on the fuel pump priming wire.an unhooked both fuel lines to the tbi.could hear fuel pump running but no fuel at the supply line.so i think i blew the hose on the fuel pump outlet in the tank or the pump gears are shot.my money is on the first option.will keep you posted.now i am gonna have to look at a wiring diagram to see if the starter sends power to the ecm to signal it a start attempt is being made.again thank you very much for your reply back.
Old Sep 10, 2018 | 11:39 AM
paul1805's Avatar
got it was a bad fuel pump or a blow hose between fuel pump and sending unit.fired right up.thank you everybody for your help.
BovineZro
Sep 26, 2016 04:53 PM
firebirdta84
Sep 20, 2016 01:06 PM
chas0218
Sep 15, 2016 05:22 PM
Nik Smith
Sep 14, 2016 04:43 PM
Vader
Mar 16, 2002 10:58 AM
