1986 LG4 Code 41
1986 LG4 Code 41
Hello,
I'm sorting out some issues with my new 96 Camaro and I pulled the codes today.
The only code stored was a 41. According to another site that means "Poor electrical connection, open or short in circuit; defective distributor pick up coil; fault in the MAP or differential pressure sensor circuit.".
I did disconnect the connectors at the coil at one point to hook up an external tach, so I will connection the battery and try clearing the codes to see if they come back. But if this one comes back any ideas on what to check first?
Thanks!
Ian
Thanks!
Ian
