power steering pump install on 1987 TransAm
Old Dec 14, 2018 | 12:17 PM
rgauder's Avatar
Car: 1987 Trans Am
Had to remove the brackets to get my A/C and driver side manifold off and now I'm having trouble remembering how the power steering pump brackets bolt back on. Anybody have any pics or diagram. A/C is not going back on. Car is a 1987 TransAm with 305 tpi.
Old Dec 14, 2018 | 05:08 PM
rgauder's Avatar
Car: 1987 Trans Am
Re: power steering pump install on 1987 TransAm
Or can someone point me to a reasonably priced aftermarket bracket?
Old Dec 14, 2018 | 05:16 PM
GeneralDisorder's Avatar
And the answer is - serpentine belt swap.
GD
Old Dec 14, 2018 | 10:05 PM
rburrow87's Avatar
Car: 1975 Pontiac Firebird Formula 400
Engine: SBC 350 w/Pro-Flo 4
Transmission: M29 T56
Axle/Gears: Stock 10 bolt w/3.42 and new Auburn
Some decent pics of the v-belt PS/AC brackets are here:
https://www.thirdgen.org/forums/engi...ring-pump.html
https://www.thirdgen.org/forums/tech...p-bracket.html
Serpentine swap would be cool if it didn't require another alternator, water pump, AC lines, who-knows-what for the AIR pump, and pulleys. F-body serp setups don't seem to come up often or stick around long at the junkyards down here. Probably do it someday. But for now, proper belt alignment and some quality (Continental Elite AKA Goodyear Gatorback) belts are pretty good. I am definitely jealous of how easy it is to upgrade the AC compressor to a Sanden on the serp setup though.
Old Dec 14, 2018 | 11:18 PM
It also takes about 15 seconds to change the serp belt.... which last a long time and never makes a peep.
The serp setup is so much superior it's almost laughable. Yeah it requires some work but the parts can be found used online pretty regularly.
GD
Old Dec 15, 2018 | 10:13 AM
rgauder's Avatar
Car: 1987 Trans Am
Thanks rburrow87.
BuiltZ28
May 11, 2016 02:32 PM
92RSConvert
Sep 12, 2014 07:20 PM
PETROC
Oct 10, 2006 07:06 PM
Thirdgen89GTA
Apr 14, 2005 09:40 PM
TA82
Jul 3, 2001 10:19 AM
