WTF is wrong with my engine?
Old Jan 14, 2002 | 06:13 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
alright ok, it runs it idles, when it gets to 30mph it seems liek it doesnt want to go anymore and liek it wants to shut off, it bogs so bad at that point an dI feel like Im just gonna stop. We replaced the following cause we either thought they were bad or we tested them adn they were bad:
Fuel pump
Ignition Control Module
Ignition Coil
O2 Sensor
TPS
We did a computer check and it said the O2 sensor and the MAP were F'ed up. So we replaced the O2 sensor and looked at the MAP sensor, nothing was wrogn with it at all so we didnt replace it, it is in perfect condition. well not perfect but good. WTF is wrogn with my car, the engine light still stays on. It f'ed up whenever I tweaked my AV and broke the spring but I replaced it and its still messed up. Please help this is really aggitating.
Old Jan 15, 2002 | 07:11 AM
BuddyLeeX's Avatar
ttt
Old Jan 15, 2002 | 08:05 AM
scauffiel's Avatar
Clogged cat?
Old Jan 15, 2002 | 09:14 AM
BuddyLeeX's Avatar
look at my sig....I have a gutted cat...
Old Jan 15, 2002 | 11:59 AM
ChevyLuva3's Avatar
LOL it definately clogged ... nah dunno man, maybe its the computer.
Old Jan 15, 2002 | 12:10 PM
Vader's Avatar
BLX,
Your ECM is trying to tell you something with the dash light. All you have to do is listen. What error codes are you getting? There is more than one error code for either of the items you mentioned, and knowing the code would define the problem a little better.
Old Jan 15, 2002 | 02:18 PM
BuddyLeeX's Avatar
ok, well im getting a good computer check as we speak. hopefully I will know the error codes today.
Old Jan 15, 2002 | 08:41 PM
BuddyLeeX's Avatar
alright, the code was 23 or soemthign liek that, but it was the MC(ixture Control Module) or somethignliek that, and the O2 sensor, but that was fine. They found a vacuum disconnected taht was on a bracket that was just laying on the intake, I dont know if thats suppose to go on the bottom of the hood closrure or not, but it was jsut a little vacuum tube that barely stays on. They said that on the MC that is on the cabr, tehre are two wires, a blue one and a yellow oen i think, well the blue looks green now, and it is the bad wire, they told me Im going to have to get a new wire and splice it in there cause i couldnt jsut replace it, or if i did that would be oen big hassel. It runs fine now though, sometimes the light will come on again and it will be a absturd sometimes but most of the time it runs just fine. I guess im goign to have to get a new wire and splice them together.
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
dhonda200
Aug 11, 2015 11:50 PM
