LB9 305 advance timing
Old Jan 25, 2022 | 05:04 AM
Tim Newton's Avatar
Car: Corvette 1958
Engine: GM LB9 TPI 1985
Transmission: TH700R4
I have a 1985 TPI which I believe is stock, managed by an ECU with a HEI distributor (without vacuum advance as this is handled by the ECU).
The ignition map is set for 6 degrees BTDC at idle, which allows for an easy start and smooth idle and take off. What is the general consensus for full advance degrees BTDC. It’s a 4-speed auto, so cruise speed sits around 2000 revs. It shifts gears under medium load at around 3500 rpm.
To map the advance curve in the ECU, should the full advance be set around 2000 to 2500 revs without load which is where the car generally sits in cruise, or is this engine speed too low for full advance? OR Should I set full advance higher in the rev range to meet the load requirements for the gear shifts? This means that it will be less than full advance at cruising, or doesn’t this matter?
Old Feb 13, 2022 | 06:10 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: LB9 305 advance timing
Feed it what it wants. Which means seat time or dyno time.
Old Feb 13, 2022 | 08:45 PM
Tim Newton's Avatar
Car: Corvette 1958
J0hn_J0hn08
Apr 10, 2012 10:16 AM
Josh R
Aug 28, 2009 04:03 PM
paulmoore
Jan 7, 2007 02:20 PM
Ronny
Feb 9, 2006 06:41 PM
icebird_1981
Carburetors
Aug 12, 2003 09:00 AM
