10W30 vs 10w40 engine oil
Car: 1984 Trans AM
Transmission: 700-4r
Any of you fellows using 10W40 oil in your 395 ci as opposed to 10W30 as recommended in the 1984 owner's manual?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 10W30 vs 10w40 engine oil
I think you meant 305, but yes i did use 10w40 in my 305 back in the day,and in 350 now
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
It won't matter, other than 10w40 may give slightly lower fuel economy. Anyone who's run 10w40 and changed at proper intervals will have had "good luck" with that....just the same as anyone who's run 10w30 and changed at proper intervals. Either way, the engine will likely outlast the car.
