Tune Up?
Tune Up?
Hi, I just bought a 1984 Trans Am with the L69 engine. I bought it for $ 900. The only thing that I can tell that is wrong with it is that the starter is messed up. I want to take it to get a total and complete tune up, to fix anything that is wrong. Based on your experiences, how much would these tune ups run? Thanks
Travis
Travis
Car: 99 Formula
Axle/Gears: 342
Welcome aboard,
Depending on your goal, it will range
plugs and wires $40-$80
oil change $10-$25,
tranny fluid change $20-30
radiator flush $5 for antifreeze
I'm sure there are some things I left out, but others will be along to help.
oil change $10-$25,
You should also put in some carb cleaner, which runs $20. It will help also to burn some of the carbon you have on your pistons. I did that when I bought mine and it runs alot nicer...I would highly suggest it. Note: It shoots black smoke for about 20 minutes don't worry thats normal
