Fuel pump???
Old Jan 23, 2002 | 06:29 AM
my$hercar's Avatar
Fuel pump???
I was out driving the camaro yesterday when it started running like crap. When I attempted to accelerate the engine wanted to fall flat on it's face (stall). If I feathered the gas pedal it would stay running, but eventually it stalled. When I attempted to get it refired, it would run for a few minutes then stall again, after I attempted to accelerate. In the end, it wouldn't fire at all. It left me stranded 60 miles from home. Is this the fuel pump going out? I have a 83 with crossfire injection. Any help would be greatly appreciated. Thanks in advance.
Old Jan 23, 2002 | 06:37 AM
my$hercar's Avatar
I just wanted to ad that engine would backfire when I finally did get it to start and attempted to give it some gas, then stall again.
Old Jan 23, 2002 | 06:58 AM
poncho9789's Avatar
Have you changed the fuel filter? is the car giving any codes? If all that is good you might check the timing to see if when you stomped in it if the distributor moved.
Old Jan 23, 2002 | 07:02 AM
my$hercar's Avatar
I really haven't had the chance to work on it, it's still in Michigan while i'm stuck here in Toledo. All this happened to me last night.
Old Jan 23, 2002 | 07:08 AM
poncho9789's Avatar
O man that stinks good luck. If it is the fuel pump it is quite a job if you haven't done one before. good luck
Old Jan 23, 2002 | 07:27 AM
my$hercar's Avatar
I've heard its a tough job, and wouldn't you know I just filled the tank to the tippy top before I left. AARRRRGGGGG!
Old Jan 23, 2002 | 02:49 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
How far is the car from Adrian Mich???? A friend of mine runs a garage, and could prolly do ya up for not too much......
Old Jan 23, 2002 | 03:41 PM
my$hercar's Avatar
Too late. It cost $170 to tow it back to Toledo. Just under $100 for parts and $275 for labor. Not to mention 2 days of missed work. The car should be ready in a few hours. Thanks for the offer though.
Old Jan 23, 2002 | 09:14 PM
my$hercar's Avatar
What a day! After all the towing and fuel pump replacement the problem still exists. Now i'm starting to think it's the cat? I don't know...
Old Jan 23, 2002 | 09:57 PM
my$hercar's Avatar
It seems like it only happens after it warms up. When I picked it up this morning with the tow truck, it started right up, same as it did after the fuel pump was replaced. Any ideas?
Old Jan 24, 2002 | 12:19 AM
NTChrist's Avatar
Do a basic tune up. While it doesn't sound like an ignition problem, it will help rule things out if you start replacing plugs, wires, and cap.
Check the fuel filter. The garage should have replaced it when they did the pump, but some guys are lazy. If the outside is even slightly rusty, replace it.
If it's your cat, a lot of times a cat will get extremely hot when plugged. If it glows, that's usually a good sign that its plugged.
Are the injectors spraying properly?
Old Jan 27, 2002 | 01:03 PM
my$hercar's Avatar
I took all the good advise to heart and replaced the fuel filter while i'm waiting on the prom to get here. I noticed that, after I disconnected the outlet side of the filter, a small amount of fuel came out of the fuel line leading to the injectors. When I replaced the filter, and before I connected the outlet side back up, fuel was flowing out of the filter like a fountain.
Old Jan 27, 2002 | 01:09 PM
my$hercar's Avatar
Someone at the crossfire injection vault suggested the module in the distributor could be the culprit. Opinions?
Old Jan 27, 2002 | 02:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
the same thing happend to me two day s ago. it was the fuel pump. not that bad of a job if u ask me. i changed mine in the school parking lot where the thing took a crap. two bolts and three hoses. not bad if u ask me. the only tricky part was to hold up the pin in the block while trying to get the pump in under it. othere than that about half hour job. with a $12 dollar pump. just make sure u take tools with u.
Old Jan 27, 2002 | 03:57 PM
GRENDLE's Avatar
easy for a carbed car, on a FI car you have to drop the tank (1 st step remove the rear end) yuck, or you can cut the floor (a hack, yes,but if it was already done when you got the car ) . it sounded like a fuel pump or fuel filter to me. i've had the same problem before. a control module will usually just die for no reason, especially after doing something with the electrical system.check for fuel preasure at the schrater valve on the fuel rail. if it's got good presure i'd start looking at the cat.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
