Paper clip method not working
Old Nov 21, 2024 | 11:09 AM
lolodenimes's Avatar
Hi,
So i'm trying to diagnose some issues on my third gen RS V8 90 and i found the "paper clip method".
I just tried to do it but it doesn't work and my fuel injector are "vibrating" when doing so...
Is that normal?
Where the light should be displayed?
I put the wire between these two prongs, are they the good ones? I see some people talking about 6-12 and other 5-6
Old Nov 21, 2024 | 11:13 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Paper clip method not working
Are you sure it’s not the iac making the noise ?
Koeo does the mil come on ?
Old Nov 21, 2024 | 11:21 AM
i'm too specific indeed, the sound comes from "around" the injectors
Old Nov 21, 2024 | 11:25 AM
Just saw another post about the IAC:
"I didn't say to look for codes, I said to set the ALDL up to pull codes, turn the key on, and put a couple fingers on the IAC to make sure it's working. It'll be vibrating if it's at least trying to work. Setting the ALDL for codes does a couple things besides blinking the SES light... Turns on the radiator fan, closes off emissions solenoids (or does it open them? Either way, the ECM does the reverse of what's normally done KOEO) on the EGR and charcoal canister, and the ECM also closes off the IAC passage by extending the pintle inside the IAC (which is why the ALDL is jumpered for about 10 seconds before the IAC is disconnected to set the base idle speed)."
So the sound is normal
Old Nov 21, 2024 | 11:27 AM
Engine: Lb9
Transmission: M20
so no mil koeo without the jumper ??
Old Nov 21, 2024 | 11:43 AM
What is "mil koeo"?
Old Nov 21, 2024 | 11:48 AM
The only light flashing on the dash is "infl rest"
Maybe i need to rebuild the dashboard...
Old Nov 21, 2024 | 12:04 PM
Engine: Lb9
Transmission: M20
if the malfunction indicator lamp doesn’t come on key on engine off . Pull the bulb see if it’s good
Old Nov 21, 2024 | 12:11 PM
i just bought 12 led bulbs. I'll change all of them saturday and see if it works!
Old Nov 21, 2024 | 05:00 PM
Engine: Lb9
Transmission: M20
Led 194 have a polarity , if backwards it will not work.
Old Nov 26, 2024 | 08:47 AM
I'm back!
So my leds doesn't have polarities, that's a plus.
The paper clip method works but i only have the code 12 showing....
And my "infl" light is always showing... (right to "engine maintenance")
Old Nov 26, 2024 | 09:48 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Code 12 means the ECM is working and sounds like there are no other stored codes. What issues are you having that you are trying to diagnose?
"infl" light is related to the air bag system and is separate to the ECM.
Old Nov 26, 2024 | 09:51 AM
At the moment, it start and run well until 30 secs when the motor starts to get hot and at that moment the idle start to drop and the car stops 20 secs later.
I can accelerate without problems.
So for the "infl rest' light, what can i do?
Oh and on an other note, my temp and gas gage are not working =(
I will try to diagnose the temp sensor if you know how to look for.
And for the gas.. i duno, my pump is brand new.
Old Nov 27, 2024 | 08:44 PM
Vader's Avatar
Until it is running reliably, the air bag (Infl Rest) lamp being on would be a secondary concern. SIR/air bag faults should have no bearing on engine operation, and the only potential common problems affecting both simultaneously would be power and ground wiring.
anesthes
Jun 4, 2017 10:32 AM
evilemokid94
Nov 16, 2010 05:18 PM
Fire"Dutch"Bird
Oct 5, 2010 09:48 AM
lakeffect2
Jun 2, 2008 07:56 AM
Jay
Apr 23, 2008 02:30 PM
