Rookie valvespring question
Old Apr 30, 2025 | 07:16 AM
Andreas_91GTA's Avatar
Car: Trans Am GTA 1991
Engine: L98 with Super Ram and Fitech
Axle/Gears: 3.23:1
I have a fresh set of "performance alu heads", equipped with springs to handle 0.600" lift from a hydraulic roller cam
Seat pressure closed 145 lbs
Open @ .600 lift 325 lbs
But, I have no intention to change cam from the stock 1991 tpi 350 cam, which should be the 10111773 with .441/.457 lift with 1.6 rockers (which I will use). So, safe to say I have a good margin until coil bind. I have more-than-enough spring for my cam and the question is: what will go south first, if anything? Will I stretch the timing chain, grind cam lobes or what? In my head everything should be fine.....but my head is not to be trusted.
Will everything be ok?
Old Apr 30, 2025 | 08:15 AM
Re: Rookie valvespring question
Nothing will be stressed. It's fine.
Old Apr 30, 2025 | 08:27 AM
Axle/Gears: 3.23:1
Great to read @sofakingdom ! I tend to stick for the worst possible scenario as the truth in everything I do to the car and it takes the fun out of it. Now I'm longing to tear it down (again)
Old Apr 30, 2025 | 06:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Should be fine. You changing lifters or reusing?
Old May 1, 2025 | 02:13 AM
Axle/Gears: 3.23:1
Reusing. The engine was rebuilt 3000 miles ago by the previous owner. I don't know what stuff was changed but he was extremely picky about everything being stock.
Edit: checking old pictures from the rebuild (sent by the guy I bought it from) I have at least a double roller chain and new bearings, including cam bearings. But....do I have the stock cam or some stock-type comp cams. I really don't know? Anyway, the car behaves like stock. Real strong 800-5000 rpm
Old May 2, 2025 | 03:10 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Sounds like something was done to it. I thought a stock L98 choked out at 4500 rpm?
Old May 2, 2025 | 03:22 PM
Axle/Gears: 3.23:1
Well, when I got the car I put a SuperRam and Dyno Don headers on it. Better heads are the last piece of the puzzle, until that puzzle means a new cam. I really don't wanna mess with a new converter so if I'd change cam it'd be something close to stock anyways. Let's just say my quest is optimizing the stock camshaft
Old May 2, 2025 | 03:33 PM
LiquidBlue's Avatar
Transmission: MD8
Is that why you are changing to 1.6 rockers, to get more out of the stock cam? Sounds like you are unsure which cam you have, you mentioned a comp cam?
Old May 2, 2025 | 03:57 PM
Axle/Gears: 3.23:1
Changing from stamped steel to full rollers was the first thing I did when I got the car three years ago, three moths later I bought a Super Ram and headers, following year I bought the heads but decided not to go with them until I had them checked - and now they are checked and ready to go.
Yes, I am unsure about the cam but it certainly feels like stock performance rpm-wise.
About the uncertainty - It just seems strange to spend thousands on a complete rebuild, change all the bearings, put new valves and springs in the original cast iron heads (new lifters and pushrods btw) and then put the old cam in. Not that the previous owner was interested in high rpm but I can not be sure it's an original GM cam since most of the other stuff was new. It would be much harder to find one of those original cams instead of going with a mild comp cams (or other), especially over here in Europe. It would be cool to know whats in there but not so cool that I wanna remove the waterpump, damper, cover and chain especially in my sorry excuse for a garage.
Old May 5, 2025 | 04:55 PM
Axle/Gears: 3.23:1
Ok, measured the lobe lift with a dial indicator and came up with .420/.430 (with 1,5 rockers). Will measure some more tomorrow. First time ever doing this so I need some practice.
Also reading old mails from the seller where he tells me the cam is new, which sounds logic since bearings, lifters, chain etc. are new. I looked at Rock Auto and suspect the Melling ccs40
Old May 15, 2025 | 10:54 AM
Axle/Gears: 3.23:1
Pulled the cam today. It was a stock CPC 773, possibly the original, which now is being replaced with a summit 8800. Will probably still feel about the same. Maybe a little bit stronger midrange.
Next headache will be reinstalling the timing chain cover. I have a one piece pan gasket (which I intend to re-use) and a pan brace. I see a lot of oh-$hit-I-give-up coming my way.
Old May 15, 2025 | 02:57 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I was just going to suggest trying the Summit 8800 cam.
87iroczzz
Mar 18, 2008 12:43 AM
91greenbird
Nov 24, 2004 08:41 AM
TBI305Camaro
Aug 6, 2002 03:04 PM
John 89 Formula
May 22, 2002 10:12 PM
Iroc n roll
Apr 18, 2002 07:04 AM
