ecm power routing question/problem
Old Feb 4, 2002 | 07:25 AM
JeffC1500TBI's Avatar
ok.. I'm just wondering how sensitive the wiring to the ecm is? on the back of the firewall on the pass side there's a cover where the fuel pump fuse & relay is located.. there's also some screw terminals.. now the far one is actually I think an 8 or Gauge wire that comes from the batt.. I believe it powers the ecm.. gm had it running down and along the frame with the starter wire .. I didn't like that so when we put the engine in I ran it up alond the fender and up the big wire loom that goes to that terminal.. would this affect any sensor readings at all? I don't belive so but I thought I'd check..
thanks
Old Feb 4, 2002 | 07:34 AM
Hellraiser's Avatar
Re: ecm power routing question/problem
thanks
The only real concern when dealing with the ecm (or any computer really) would be to use the same guage of wire, and keep the lengths as close to stock as possible. As long as you're not adding unecesarry resistance (read - huge lengths of wire), or in any other way changing the voltage measured at the computer (sometimes the values looked for by the computer have VERY little room for error, hence the problems folks seem to have with grounds to the ecm and such) there should be no difference at all. I'd say you're good to go.
89GTAOz
May 16, 2020 09:31 AM
stalkier
Dec 6, 2015 11:25 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
