When to go to MAIN STUDS.
Old Feb 11, 2002 | 10:04 PM
Hulk0202's Avatar
I'm building a 4-bolt 350 that will probably never see more then 400/400. Im having the main caps align bored because I think one is from a diffrent block.I would like to know at what point should you switch to something like ARP main studs? I've come to believe that the ARP (studs/bolts)? for the rods are pretty important. All help would be greatly appreciated. Im taking care of this tomorrow. Thanks
Old Feb 11, 2002 | 10:59 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i like to use them on every rebuild i do personally.
Old Feb 11, 2002 | 11:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 4 bolt doesn't really need them but they are a good added protection. If you had a 2 bolt then the stud kit is highly recommended. Even better is splayed caps.
If you do plan on using studs, you need to have them installed before getting the block align bored.
I use main studs in my race engine and it's only a 2 bolt block.
Old Feb 12, 2002 | 04:58 AM
ede's Avatar
ede
considering how cheap thjey are i use them for every 2 bolt preformance rebuild i do and usually for the 4 bolts as well
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
efiguy
Sep 27, 2015 01:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
