cam for my 305
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
cam for my 305
hey guys i have a 305 tbi right now and i am lookin to switch over to carburation so i don't run into alot of problems when i get a cam. my question is what is a good roller cam that has a real nice lopey idle and good performance. theres a guy on the tbi board with a non roller tbi 305 and he has a crane compu-cam that sound so awsome. but hes havin all kinds of computer probs. his cam specs are 216/228 dur. @.050 454/480 lift. its an awsome cam. does any1 know of a cam that has a real lopey idle and is a roller?? well thanks guys. oh yea and what is a 3 port fuel pres. regulator. wuts the diff from a 2 port. thanks
lol yeah I imagine he's having computer problems. That cam is too big.
Look for a zz4 takeoff cam. They can be found really cheap for a roller..and would make a great all around cam in a 305.
Transmission: 4L80E/4L80E
Re: cam for my 305
I used the Crane cam because I had to stick with a flat-tappet block. My original plans included an LB9 roller block and ZZ4 take-off cam, but I found out in prepping the block that it had a couple of cracks in the lifter valley. I chose the Crane cam for my LG4 engine because it was the closest I found to the ZZ4 specs (208/221 duration @ .050, .474/.510 lift, 112 LSA). I wouldn't use a ZZ4 cam with unmodified stock heads, though - too much lift on the exhaust.
If he's having computer problems, I suspect improper implementation, not a fundimental problem with the Compucam. I don't have first-hand experience with TBI, but I haven't heard anything that makes me think issues like this can't be worked out with minimal effort.
Car: 2006 Silverado 1500
Engine: 5.3L
yeah, you can but if you do your going to lose power. chosing a cam isn't as simple as big and little or lumpy and small. picking one with the wrong specs can cause a power loss that will show up on a dyno and in the car will be a terrible driver compared to the correct cam.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
FIRST, do yourself a favour and forget about wanting a lopey idle or a lumpy idle. No one with an ounce of brains on this board is going to help you. The people you want to talk to here are the SERIOUS engine builders who know how to make torque and horsepower, NOT the juveniles who think a lumpy idle is "cool."
If after going through the correct process of cam selection your engine has a bit of a lope to it, so be it. But that is never to be your sole objective. Capiche?
Good.
Listern to 57kid, he knows of what he speaks.
Also, a really good cam for a non-roller block carbed 305 is the Comp Cams XE256. It's the one they recommend for the street.
Good.
